Horn fuse/circuit causing voltage drop?
Old Jan 22, 2024 | 02:51 PM
Jamiie's Avatar
Default Horn fuse/circuit causing voltage drop?
Hi,
Ive recently found that my Mazda 2 alternator is not properly charging. A quick check shows that it’s only around 12/13v not the 14.4v it should be. Alternator has been changed recently so I knew that was good.
It appeared to be something drawing a large amount of power a couple second after starting. After pulling the fuses one by one I located the issue to the horn fuse. Once this fuse was pulled the battery read at a constant 14.4v solid.
I have isolated the horn at both the horn itself and the steering wheel and this has not resolved the issue.
does anyone know what else is attached to the horn circuit that might be causing this issue?
video attached for reference
Old Jan 22, 2024 | 03:20 PM
Does the horn still work?
It really helps that you give the vehicle information as if you would looking up a part on the internet ????? Like the year at least?
Old Jan 22, 2024 | 03:22 PM
Jamiie's Avatar
yes horn works absolutely fine
Old Jan 22, 2024 | 03:26 PM
You didn't give me time to edit my response. hahaha! fast on the keyboard?
Old Jan 22, 2024 | 03:31 PM
Looking generically over the year coverage of your Mazda's you could have a BCM issue?
Old Jan 22, 2024 | 03:34 PM
Before you ask and if you are going to ask HOW-TO the best advise at this point is to surf the internet for the procedure. It is fairly simple but waaaaay to much for me to even type when the information is available to read.
tff
May 21, 2024 07:10 AM
Pokeypuppy
Sep 20, 2020 07:39 AM
swolk99
Aug 29, 2016 03:23 AM
lmeadows52
Jul 22, 2011 07:32 AM
Alucard
Jul 23, 2006 12:47 AM
