CVT gear box
Old Aug 16, 2018 | 12:24 PM
bnd_ck's Avatar
Default CVT gear box
Hi,
does Mazda 2 (demio) 2007-2010 model has CVT transmission. I am planning to buy used 2008 1.3 L clocks 50?. what should I look for to verify this?..
Many thanks
Old Oct 6, 2018 | 10:20 PM
scubaman's Avatar
I own a 2009 Demio with a cvt transmission. About 160000km
are you trying to determine if the Demio has a CVT transmission?
1) locate the transmission dipstick, look at the top of the stick or pull it out and look for writing stamped on the stick. The type of fluid required is usually marked on it. The CVT fluid is different than the regular automatic transmission fluid.
If it says 3320 on the stick it’s a CVT transmission, if it says M5 (or MV) it’s a regular automatic.
2) if you have driven an automatic before you will know that there are definitive changes between gears. On the cvt there are no definitive changes.
3) the gear lever usually only has D and Ds. There are no numbers
shaun ayres
May 21, 2010 11:32 AM
ivailo_pace
Sep 22, 2008 02:17 AM
longrange
Nov 26, 2007 01:13 PM
Parody
Nov 5, 2007 07:52 AM
lapinkulta
Oct 27, 2006 10:51 PM
