air con low port
Old Jun 9, 2020 | 10:24 AM
Al West's Avatar
Default air con low port
I've got a Mazda 2 Capella 2007 (old shape). I need to know where the high port connector is for adding new air con gas R123a.
There is a port on the left hand side of the front bonnet rail (looking at the engine from the front) but the connector I have on the hose 13mm does not want to fit. Although when I measure the connector it is 13mm!
I'm worried that this might be the high connector rather than the low one which I think I need to connect to.
I can't seem to find any documentation which shows high and low connector placement on the car.
Any pointers as to where I might find and identify the ports would be very much appreciated.
Thanks Al
Old Jun 9, 2020 | 10:29 AM
Al West's Avatar
sorry should have read looking for low port connector. as this is where I believe new gas is added....I suppose I need to locate them both really.
Old Jun 10, 2020 | 09:03 AM
Mazda 2 is a small sedan or hatch. Capella is the JDM version of the 626. I'm confussed???
A/C servicing is hooked up to both high pressure & low pressure valves/ports, or are you trying a dodgy DIY canister from the auto store?
Old Jun 10, 2020 | 10:14 AM
Al West's Avatar
Hi, Thanks for the reply. The Capella version of the 2007 Mazda 2 is the top of the range with the electric windows, air con and central locking.
This is in the UK.
I need to locate both high and low connector. I believe the low port is the one to which you connect your hose and gauge.
Thanks Al
Old Jun 15, 2020 | 10:24 AM
Al West's Avatar
I've found it...... The low port air con connector that is....
its under the offside (Driver in UK) wheel arch. You have to take out the plastic cover, about 8 screws and its sitting just below the headlamp area.
Whoever designed this wants shooting! I understand that on some models its been moved into the engine bay.
Al
nickkaps
Nov 25, 2019 03:48 AM
Pete Shelley
Sep 29, 2019 01:29 PM
LegacySurge
Feb 26, 2018 12:56 AM
willfitz
Feb 9, 2013 09:21 PM
Mokal
Jan 9, 2013 03:37 AM
