2003 Mazda 2 PCM wiring diagram.
Old Apr 6, 2020 | 11:36 PM
ygkkarthik's Avatar
Default 2003 Mazda 2 PCM wiring diagram.
Hi Guys,
can anyone please help me to diagnose the P0610 code on my Mazda 2. Before I take it to a mechanic, I want to check all the wiring harness. To do so I need a wiring diagram to see which Pin in the PCM is ground and how many total grounds are present in CAN BUS Harness. So please someone help.
Thank you...
Old Apr 7, 2020 | 04:30 AM
PM sent
Old Apr 7, 2020 | 05:15 AM
ygkkarthik's Avatar
Thank you so very much Grim. Cheers
Old Oct 16, 2020 | 06:50 PM
eagleprime's Avatar
Hi,
I've got the same issue with a Mazda 3 (m.y. 2006 BK sedan with 77kW 1.6l petrol engine); do you happen to have a diagram for me as well?
Old Oct 17, 2020 | 03:51 AM
Not for a 1.6. They were never release in Japan or Australia.
Old Apr 19, 2023 | 02:44 PM
Kudzie Furayi's Avatar
Default Mazda
PM sent
Hie Grim
I'm new here on this forum, and I have been reading your threads I noticed you good at what you do,
Sir I have a problem with a Mazda 2 dy 2004 model immobilizer, immobilizer light flashing, car starts and dies immediately it won't idle up or rev up,
I would like to know if you have any solution/s to this or you might have immo off, virgin file or even how to bypass the immobilizer.
Thus whole issue started when I tried to programme new ECU using forscan, the original ECU is burnt out I cant extract anything from it, I would really appreciate if you could help me out on this issue.
Yours sincerely
K Furayi
Old Apr 25, 2023 | 12:39 AM
I don't have any info regarding immobilizer bypass.
Mazda6SR
Feb 13, 2020 12:10 PM
ragtop76
Mar 8, 2018 02:01 PM
scorched_onion
May 14, 2010 09:29 PM
anthonytsi
Feb 23, 2009 03:52 PM
esloyer
Jun 15, 2006 11:55 AM
