thermostat?
Old Dec 29, 2009 | 01:37 PM
yukonjonny's Avatar
Default thermostat?
I recently had some trouble with the high speed fan coming on while idling. After investigating, I replaced a leaking water pump and the thermostat. I flushed and replaced the coolant at the same time. Unfortunately I still have the fan problem. The temperature gauge on the instrument panel usually shows about half way (i.e not over-heated). I also noticed that the lower radiator hose does not get hot. I thought that I might have got a bad thermostat, that was stuck in the closed position, so I went and got another one and it still didn't fix the problem. Anyone have any ideas what else could cause these symptoms? Thanks.
lf4317
Jan 5, 2007 09:06 PM
cugene
Nov 14, 2006 11:58 PM
Gnashing
Oct 10, 2005 11:21 PM
bluemx693
Sep 17, 2005 04:01 AM
john b
Nov 28, 2004 01:23 AM
