Problem with COPs on 2005 Tribute 3.0
Old Nov 19, 2013 | 01:04 PM
KMag's Avatar
Default Problem with COPs on 2005 Tribute 3.0
My 2005 Tribute developed a miss the other day. To be brief, I chased it down to a bad coil on cyl #4. I checked 5 & 6, and both were firing. I swapped to coil from #4 to #5 and it was not firing. However, when I swapped both the #5 and #6 (working coils) to the #4 cyl, neither of them would fire. I put them back in their respective places and they fire OK.
So I know that the #4 coil does not work, and there is also some type of problem with the wiring leading to #4. Has anyone experienced this before?
KMag
Old Nov 19, 2013 | 07:18 PM
KMag's Avatar
I found a FSM with a Wiring diagram that I purchased and is on the way to me. I'm thinking that the tribute must have some type of ignition module or a device to send the signal to the coil to fire. Anyone have any thoughts on that?
KMag
Old Nov 24, 2013 | 05:54 PM
KMag's Avatar
I have confirmed that the #4 coil failed and then it damaged the PCM. So I'm looking for a used PCM. It is the same as used in the 06 Tribute and the 05-06 Escape. If anyone has any leads on a used one, I would appreciate the info.
KMag
Mazda4Me
Apr 23, 2014 09:10 PM
craziecracker
Mar 26, 2012 01:24 PM
virgin1
May 28, 2009 04:43 PM
dentinger
Dec 2, 2007 10:56 AM
rizakag
Mar 27, 2006 08:29 AM
