Oil light coming on 2008 Tribute
Just recently the oil warning light has been coming on on my 2008 Mazda Tribute. It only comes on when I come to a stop and the engine is idling. Not sure if it is a sensor or maybe the oil pump going out.
Assuming your oil is the right level and grade you need to either swap out the sensor or test the pressure with a known good shop gauge to find whether you have a real oil pressure problem or not.
Normal sensors trigger at VERY low pressure so you need to do it fairly urgently - does the engine knock or rumble under idle or load? |
No the car doesn't knock or rumble at idle, the strange thing is today the light never came on
Originally Posted by dmwise
(Post 164156)
Good sign there is no rumble. |
Also how old is the oil if it starts to break down when hot it thins out and is not pumped around with as much pressure
I have used cheaper oil a couple of times. and had to do oil changes more frequently I now do mine every 5000 kms along with the oil filter for about $50, it is cheap insurance. To get at the oil pressure switch you need to lower the air-conditioning compressor as the switch is directly above this |
I just changed the oil couple days, and had same problem when comes to a stop, the engine is rumble under idle, but did not happen before oil change, I think with the engine over 300K suits to use the oil thicker like 10W/40 or so, but the guys at Auto part gave me 5W-30, I had other engine spare swapped switch, but problem still remain....will try thicker oil today.....hope it gone
Try something like Castrol GTX 15w40.
Is that at a synthetic oil or should I even consider using synthetic in the Tribute
Depending on your market, there is a Multigrade Mineral & a synthetic version.
