Oil light coming on 2008 Tribute
Old Sep 20, 2017 | 08:22 AM
dmwise's Avatar
Default Oil light coming on 2008 Tribute
Just recently the oil warning light has been coming on on my 2008 Mazda Tribute. It only comes on when I come to a stop and the engine is idling. Not sure if it is a sensor or maybe the oil pump going out.
Old Sep 20, 2017 | 04:12 PM
simonsi's Avatar
Assuming your oil is the right level and grade you need to either swap out the sensor or test the pressure with a known good shop gauge to find whether you have a real oil pressure problem or not.
Normal sensors trigger at VERY low pressure so you need to do it fairly urgently - does the engine knock or rumble under idle or load?
Old Sep 20, 2017 | 05:47 PM
dmwise's Avatar
No the car doesn't knock or rumble at idle, the strange thing is today the light never came on
Old Sep 20, 2017 | 06:29 PM
simonsi's Avatar
Quickest is to inspect the wiring as a short or break can give this problem, then swap the sensor if one is available easily...or as I said, get a shop gauge put on it to see what the pressure really is.
Good sign there is no rumble.
Old Sep 21, 2017 | 03:54 AM
peedee's Avatar
Also how old is the oil if it starts to break down when hot it thins out and is not pumped around with as much pressure
I have used cheaper oil a couple of times. and had to do oil changes more frequently I now do mine every 5000 kms along with the oil filter for about $50, it is cheap insurance.
To get at the oil pressure switch you need to lower the air-conditioning compressor as the switch is directly above this
Old Sep 30, 2017 | 07:25 PM
Maz2004's Avatar
I just changed the oil couple days, and had same problem when comes to a stop, the engine is rumble under idle, but did not happen before oil change, I think with the engine over 300K suits to use the oil thicker like 10W/40 or so, but the guys at Auto part gave me 5W-30, I had other engine spare swapped switch, but problem still remain....will try thicker oil today.....hope it gone
Old Oct 1, 2017 | 08:14 PM
Try something like Castrol GTX 15w40.
Old Oct 20, 2017 | 04:41 AM
dmwise's Avatar
Is that at a synthetic oil or should I even consider using synthetic in the Tribute
Old Oct 21, 2017 | 04:27 AM
Depending on your market, there is a Multigrade Mineral & a synthetic version.
Reggaetrix
Feb 11, 2017 09:44 PM
stubbylong
Mar 10, 2013 03:26 PM
gwen79
Jul 16, 2007 10:55 AM
cugene
Nov 15, 2006 12:38 AM
audioexcels
Feb 9, 2006 07:40 PM
