Ignition Switch - No Start
Old Aug 18, 2021 | 06:59 AM
JVP's Avatar
JVP
Exclamation Ignition Switch - No Start
My 2008 Tribute has difficulty starting. Usually takes several turns of key to be able to hit the start portion of switch. Mechanic replaced ignition switch 2 -3 years ago, but the problem slowly came back. I suspect now that the key barrel has worn inside and there is enough play in there where it can't turn the ignition switch enough to start car. I currently have the ignition switch hanging out and once the key is inserted in the column, I can start the car using a screwdriver to turn the ignition switch. Not a good system.
Somewhere online I read where cost to replace whole system on steering column at dealer is $1000 - $1400. (Have to remove steering wheel and airbag) Almost more than car is now worth. There's a Youtube video where a mechanic claims to have fixed the problem by cutting away some plastic edges off the ignition switch so that the switch can be inserted in the column in a slightly rotated angle that insures the key will be able to turn the swtich enough to start.
It's a crazy idea - even uses a drywall screw to secure switch position.
Has anyone heard of this approach? What are the downsides? What do you think my other options might be for this car?
Old Aug 19, 2021 | 11:29 AM
JVP's Avatar
JVP
Default Ignition Wiring Diagram
Anyone have a diagram of the wires to the ignition switch so I can figure out what is what. Color codes to pins would really help. There are 7 pins.
Jbmazda
Dec 1, 2018 04:54 AM
CHeinze1
Jan 3, 2018 04:38 AM
kcss218
Aug 23, 2011 05:02 PM
rainman2736
May 11, 2007 10:30 AM
GRHoward1937
Nov 2, 2006 12:16 AM
