Here's how to remove trim to change shocks in Tribute
5 Attachment(s)
This is for my 05 Tribute..should be the same or real similar in related models..
Hope this helps someone Well I looked around on the interwebs for a description of how to do this, and I could not find one. So, with little other choice, I decided to blunder through and figure it out as I went along. To save everyone else from this future problem...I took pics and will share them here. Start by pulling the weatherstripping loose in the middle of the rear of the car Attachment 5478 Pull it off on both sides about to the corner Attachment 5479 Take a flat blade screwdriver and gently (hey the whole world is made of brittle plastic these days) pry up to pop the plastic clip loose Attachment 5480 Continue until the plastic trim comes completely loose Attachment 5481 looks like this..dont mind that stain..god knows what that is Attachment 5482 |
5 Attachment(s)
Then move up to the back door ( i did passenger side first but it dont matter)
pop the trim circle from the seat locking bracket Attachment 5473 Then look down and find the plastic cover on the kickplate plastic trim and pop it open with a screwdriver Attachment 5474 This is probably the hardest part of the whole thing..You pry,swear, pull etc to get the trim piece and that little plastic "pop-it" out Attachment 5475 Looks like this when you get it out Attachment 5476 The plastic is bendy so you can just pull it out of the way like this Attachment 5477 |
4 Attachment(s)
Then pull the weatherstripping loose along the rear panel
Attachment 5469 Pry carefully (again its just plastic but its probably the most expensive plastic in the whole world if you break it) from the bottom of the plastic wall panel up towards the window Attachment 5470 Then head to the back of the car and repeat the process Attachment 5471 The only tabs that should still be holding are under the window..Just get your hands under and behind the panel and give it a firm tug..It'll let loose. And there it is..the top of the shock! Attachment 5472 You did it..now just repeat the process for the other side and go get a beer or six. Coming soon...Mazda Tribute Shock Replacement |
