HELP! Please
Old Jun 17, 2013 | 06:35 AM
turboturney's Avatar
Red face HELP! Please
Hi, Pulled 2 codes P0172 & P0430 today after rough idle and no throttle pick up when starting up for the 1 mile trip home.
This is the third time that my engine has done this.
Last week I had to use Super unleaded as premium had sold out,
also used some injector cleaner in the fuel system
I have changed the MAF Sensor and fixed a vacuum leak and now these codes are showing. Any Ideas Please
Old Jun 17, 2013 | 07:28 AM
tanprotege's Avatar
Hey Tuboturney: Would you mind to put your car's information in your signature?
P0171 is a lean condition in bank 1. If it is a 4 cylinder that's the only bank you have. usually it is caused by a vacuum leak.
P0430 lets you know that the catalytic converter is now below 95% efficiency. Maybe it is 94% or 92%, we don't know.
When the tank is about half full, fill in 4 l of Lacquer Thinner, NOT PAINT THINNER!! and drive about 100 miles on the motorway. Don't spin it above 5000 rpm.
To clear the code, take off the battery negative and step on the brake 9or turn on the headlights, push the horn button. That drains all residual voltage from the computers and thus they are reset.
Old Jun 17, 2013 | 07:43 AM
VIDEO for Cat Code, Lacquer Thinner:
VAC LEAK FINDING WITH A CIGAR:
Old Jun 18, 2013 | 06:07 AM
I have done what you asked and I have put 2 pics in garage.
I have code P0172 Rich condition. Must be the Super unleaded 98 rom. that is in the tank
Lacquer Thinner is very hard to get in the UK
Thank you tanprotege
Old Jun 18, 2013 | 06:11 AM
Thank you. UseYourNoggin - Very interesting viewing
Old Jun 18, 2013 | 09:02 AM
tanprotege's Avatar
I am sorry, i was reading your post with my blind eye!
A rich condition is often caused by a leaking injector. This could also contribute to a lower cataltytic efficiency. In fact it could kill your catalytic converter and set you back a few British Pounds.
There are more possible causes:
What causes a rich air/fuel ratio? - Yahoo! Answers
Lacquer thinner has become quite expensive, but I assume that in the UK it is the environmental laws that make it hard to come buy. Talk to a body shop if they can get you some. But first find the cause of the rich condition.
Old Jun 19, 2013 | 11:26 AM
would Acetone do the same job? as Lacquer thinner as it is easier to buy in the UK 5Ltr. = £17.50 with Free P & P
Old Jun 19, 2013 | 01:21 PM
tanprotege's Avatar
Honestly, I don't know if Acetone would do. Lacquer thinner is a mix of petroleum distillates.
I do not want to recommend anything that I have not used myself. I am afraid it could do harm somewhere.
Old Jun 20, 2013 | 05:48 AM
OK I will take your sound advise and continue my search for lacquer thinners.
Just found this :- Lacquer thinner = U.S. term / cellulose thinner = U.K. term
Last edited by turboturney; Jun 20, 2013 at 05:57 AM. Reason: more knowledge found
Old Jun 20, 2013 | 06:55 AM
tanprotege's Avatar
With any luck this will take you to the MSDS of Clean Strip lacquer thinner showing its componants:
http://www.google.com/url?sa=t&rct=j...kDl_I_oCHTHE9w
