Front End Clunk: None of Usual Suspects
The ever-present front-end Mazda Tribute "clunk." It's been with me seven years but only this week did it get bad enough that I am scared for my safety when using the vehicle. Left side produces a dangerous sounding clunk when going over even mild bumps, particularly on roads that are continuously bumpy. This was first noticed when I went up a logging road with a friend and we both noticed a distinct clunk from front end. The sound is not reproduce able by rocking the car, turning the wheel, etc. The only way to produce the sound is to drive the car over a bump or a dip on the front left.
Details:
Known Issues:
Details:
Known Issues:
- Severe clunk when turning steering wheel in opposite directions, but no noticeable play.
- Severe clunk in left front area when passing over bumps (including small bumps or continuous bumps on a rough road). Also can be felt through floorboards lightly
- Severe inner wear was noted on the two front tires prior to replacement.
- Rear right shock blown (awaiting parts).
- Worn tie-rods causing clunking (6 years ago) - Both tie rods replaced.
- Damage-caused play in steering wheel from brute force (5 years ago) - Steering wheel lock pin re-seated as it had been dislodged.
- Catastrophic failure of front right ball joint (4 years ago) - Both ball joints replaced.
- Catastrophic failure of all external brake lines (1 year ago) - All external brake lines replaced.
- Sway Bar Links (Excellent condition, well lubricated)
- Ball Joints (Excellent condition, well lubricated)
- All Brake Lines (Excellent condition, free of cracks) and pads (excellent condition, rotors showing even wear)
- Control Arm
- Sway Bay Links
- Ball Joints
- U-Joints
- Brake Components
- Strut (both Shock and Spring OK, as far as I can tell)
