Which exhaust system gasket??
I have a leak in the front of my exhaust system. It is the gasket between the flexible joint, and is located right in front of the oil pan area. The pipe seems to come down from the cylinders and then hits this joint, then runs back towards the exhaust manifold, cats, etc...
Does anyone know what this gasket is and how I can order one?
Hopefully this makes sense! Thanks
Kyle
Kyle
Here is a picture of the gasket I am looking for. It sits right between those two plates.
link: http://img714.imageshack.us/i/0000016v.jpg/
I don't believe there is any gasket there. Those two bolts just snug-together those flanges. If that is the spot that is leaking and those bolts are tight, you might be able to add some high temp RTV to seal it up.
mxteam
Oct 24, 2007 06:52 AM
