Clicking engine noise on v6
Yes def tolerance on assembly by the sound of it “ghetto fix” Lol
i want to do this job but i wonder if there’s anything i should be nervous about?
how would i rotate the engine? Can i just move the car back and forth?
if i did the crank bolt, do u think i could do it from underneath? Or would i have to take the wheel off?
taking the cam caps off is that a big deal? Nothing is under tension right?
the cam caps will rise under some tension as the some valves will be open and under tension, undo the cap bolts evenly, a turn at a time across all of them.
So do i take them all off then put them on or one off, then put it back on?
vs taking them all off laying them down, then putting them back on
If it only talks about removing caps then I would take that to mean one by one is ok (biasing that one sideways as instructed), removing all would be akin to camshaft removal which would need the chain removing I think.
Just as an update .. I completed this TSB over the weekend. It fixed the problem.
I didn't use a screwdriver to hold down the cam cap I had my father just push as hard as he could with his hand.
When I took the valve cover off nothing was loose, I couldn't make anything click.
Taking off the cam caps i had to use a mallet to loosen because they have dowels on them.
Also I inspected the underside of the cam caps and they were all smooth, so the noise is quite a weird mystery but the TSB fixes it!
The job is not difficult, just tedious and time consuming
