CD4E Transmission woes and possible fixes?
Old May 27, 2019 | 04:48 PM
Nic Hac's Avatar
Default CD4E Transmission woes and possible fixes?
I’m determined to try and get something out of this suv I mistakenly bought. Have not ventured out to junkyard... going to try and take cross ref photos for possible 5spd conversion only if the $$ is less than a rebuilt auto trans. And I mean less than $1k.
Its an 08 Tribute i 2.3l 2wd w/160k original on trans and ?? On motor.
I’ve so far done a band aid on valve body and did not get to the pump assembly( very concerned about it). <has not been ran yet since...The seller decided to bounce around harmonic balancer and timing issues, car was running but eventually started to have rough engagement. I will be checking alignment of crank and cps here shortly this week.
after seeing the problems that this auto trans encounters, I’m looking at alternatives to try if I cannot get the auto trans to settle out.
For starters I do not know the type of manual trans is paired with the 2.3l? Not sure if the Ford Escape or merc mariner is possible donor for ECU/PCM.
Regardless, I will try to find one with 8th dig vin (Z). And if I do I will snap several photos of what Im pretty sure will need swap.
Old May 27, 2019 | 10:10 PM
simonsi's Avatar
Not sure I follow, crank, harmonic balancer and cps sensor wont affect the trans engagement.
if engagement is a bit rough have you tried a fluid change?
Old May 28, 2019 | 06:33 AM
Nic Hac's Avatar
Yes fluid has been changed, no heavy metal bits. Very fine particles at first fluid swap. I drained again and down’d The car. waiting on valve body accumulator o-ring.
mig25
Jun 15, 2024 04:22 PM
Paul Castle
Jun 26, 2018 01:11 AM
ddana88
May 7, 2015 01:23 PM
sylvan dude
Aug 6, 2014 06:54 PM
04tributelxowner
Apr 7, 2007 08:39 PM
