Bad Alternator? Red battery light - dash gauges turn off..
Old Aug 13, 2022 | 12:13 PM
boostmg's Avatar
Default Bad Alternator? Red battery light - dash gauges turn off..
Hey everyone, I have a 2006 mazda tribute v6 with 155k on it. It's getting a little rusty.
Recently i just turned the car on and had my gauges turn off for a little bit, then they turned back on, however now after driving a little longer they turned off. This is what i learned.
- The negative terminal clamp did corrode almost in half so i replaced it
- my battery was dead so i charged it fully
- i had the battery tested at napa and they said it was good
- i ran an alternator test using volt meters on the battery terminal, they read 12.3 before starting, then when starting voltage went to 17
- i then turned on the headlights and AC and voltage went to 15
- i also noticed that when i turned on the AC and headlights to lower the voltage that the dash turned back on
So from all of this i can deduce that the dash is turning off when volts are around 17.
I am trying to figure out if this is my alternator or something else. I checked the alternator fuse under the hood and it looked fine, i also checked the dash fuses inside and they looked fine.
What should i do next?
Thank you in advance.
Old Aug 17, 2022 | 02:21 PM
boostmg's Avatar
It was the alternator
rubenreyes
Jan 12, 2017 09:42 AM
Idnotvalid
Jun 16, 2015 02:27 PM
acreu61
Jul 17, 2014 03:51 AM
Jprotege
Dec 10, 2011 08:15 AM
zilla
Dec 23, 2010 11:33 PM
