HELP RX8 Makes Akward Sound!
Old Mar 15, 2006 | 02:26 AM
Extreme Philip's Avatar
Default HELP RX8 Makes Akward Sound!
My RX8 is getting a very weird sound, like a squeaky belt, when the clutch is not engaged. When you slightly press your foot on the clutch, the sound goes away. I was told that the engine does this...but no freakin way!! It sounds like a loose fan belt or squeaky pulley. I can't track down the noise. I checked the belts and they seem fine..and beside why would the belts create the sound from the clutch not engaged? Let me know if anyone else has this problem.
Old Mar 19, 2006 | 02:49 AM
Tracker's Avatar
Default RE: HELP RX8 Makes Akward Sound!
My friends sister has the same problem with her Eclipse, and we found out that the pulleys were tightened too tight, we loosened them up a bit and the sound stoped.
Old Dec 16, 2006 | 11:01 AM
bmowry's Avatar
sounds like the throw-out bearing, get it checked...
Old Jul 27, 2007 | 05:58 AM
jerseyscampi's Avatar
It's actually a faulty micro switch on the clutch pedal assembly. An upgrade fixes it.
Old Aug 8, 2007 | 11:30 AM
im_DANomite's Avatar
it is the clutch throwout bearing
cluelessgirl
Apr 4, 2010 11:00 AM
apbbnbanb_07
Jan 7, 2009 05:47 PM
EZE
Apr 19, 2008 06:04 PM
RX8_wanabe
Mar 26, 2008 04:30 PM
warzol
Dec 5, 2007 10:08 AM
