Coils
Old 04-12-2015, 09:30 AM
tocostew's Avatar
Default Coils
I know there are two different spark plugs leading and trailing but are the 4 coils the same of are they different.
Old 04-12-2015, 09:44 AM
hixx's Avatar
All 4 are the same. Replace every 30k miles unless you get the $500.00 setup. They last forever.
Old 04-12-2015, 05:51 PM
tocostew's Avatar
Is there any way to adjust the idle ?
Old 04-12-2015, 06:13 PM
hixx's Avatar
The PCM controls the idle via the idle air control valve. Cleaning the throttlebody will usually help.
Old 04-12-2015, 06:40 PM
tocostew's Avatar
Thanks having an issue with it dieing at a stop light when I idle drops below 1,000 I changed the cols yesterday but haven't got around to the plugs and wires. What else would cause it to die like that
Old 04-12-2015, 07:07 PM
hixx's Avatar
Usually low compression due to carbon accumulation on the apex seals. Throw a bottle of Techron in the gas tank once a month and a bit of Marvins mystery oil with every fillup to keep the cylinder temps down due to ethanol.
Old 04-13-2015, 08:42 PM
tocostew's Avatar
I feel so dumb today. Went out to check everything over and noticed I forgot to plug in the mass airflow sensor connector. Lol runs fine but still need to change the plugs and wires this weekend but at least it doesn't die
randl
06-06-2007 10:56 AM
rasorenson
03-08-2007 03:27 PM
dgbarnes
05-22-2006 11:06 PM
ajw
03-22-2006 11:36 AM
keninn
09-07-2005 07:47 PM
Quick Reply: Coils
