would like to find ways to get more low end
is it possible to torbo charge a non turbo engine without dammaging it
RE: would like to find ways to get more low end
It is but It can be difficult. The N/A engine has low compression rotors as well as 6 small ports rather than 4 large.
you mean the N/A has high compression rotors. The stock N/A has 9.4:1 compression rather than the Turbo which came with 8.5:1 Compression. I am actually doing a complete Turbo 2 swap to my vert.
ahh well it has the wrong rotors.
Edit: and good luck with the TII vert. I've seen them, the scoop works well with the body lines of the vert and your top already sits lower than the stock one when down. That should come together great. Al;so the Mitsu 3000GT VR-4 wing looks awesome. Someone showed a pic once, I'll try and find it for you sometime. |
actually its a vert rx-7 spoiler. i picked it up off of ebay.
I know yours is a vert spoiler, but I was suggesting after the TTI mechanical and visual swap, you could really enhance the lines and get an early 3KGT spoiler.
