Screamin Demon Tranny?? (Long)
Old Nov 2, 2008 | 02:07 AM
Sileighty_85's Avatar
Default Screamin Demon Tranny?? (Long)
First off let you let you know Im not a big Rotor Head, although Ive work on a few 7's in my day.
Im posting this for a friend (who is a Big Rotor Head) because he does not have internet in his new Aprt yet.
Anywayyyyy...
We just finished droppin in a new 2 rotor 13B in his 3rd Gen FD
Old engine and turbos were toast.
He pick up a fresh 2 Rotor 13B (street Port) from someone swapped over all good parts from his old engine, we installed a New/used T-78 twin scroll only 1,000 miles on it Ripp out all the emission crap and kept only the required solenoids that was need to make the car run. (hes done all research for wiring and stuff)
Brand new Excedy clutch Hyper single clutch kit installed
Power FC ECU
Forgot Inj. but they are larger ones Top feeds with necessary resistors wired in
Got everything installed
Engine cranks up then shoots to 3,500RPM's for 3-4 seconds then boggs and hunts for Idle for a few seconds then dies (due to PFC Initalizing learning sequence)
we cannot get the PFC to completely initalize it keeps dieing if we dont tap the throttle, but when it does idle its
Bwaaaap...1 1/2 seconds....bwaaaap..... ect
This just came to me while typing but we didnt set the Inj. Lag time, but other than the Hunting engine runs fine No rich condition, but also need to plumb in the Injector atomizer vacumm source?
Anyway sorry to get off track of the main problem, So the engine starts
but as soon as the RPM's increase above above 800 RPM's there is this horrible sceaming noise comming from the font transmission area. Doesnt matter if clutch is engaged or disengaged
Yes we put Tranny fluid in the tranny
TOB was replaced with the Excedy one provided in the kit, Input shaft and carrier being was greased
Transmission shifts fine through out all gears
first we thought it was the compressor wheel making contact with the compressor housing, Nope
Check all belts : Brand new all tight
I am certin it is a problem in the clutch area, I havent delt too much with a pull type clutch set up other than on a Supra but only once, so im not sure what all could make this sound.
The engine came out of a Automatic It had the counter weight on it, if that matters.
He aslo said he didnt change the pilot bearing he said it looked new and spun and Greased, but I dont know if ya'll PB are differnt sizes from autos to manual which I kinda leaning towards the PB all jacked up.
Like I said my friend is very knowledgeable with Rotary engines he owned a couple of FC's so this is not his first
Well sorry for the long *** post, im trying to explain it the best I can
Hopefully someone can help us out, Thanks again
Old Nov 2, 2008 | 04:46 AM
Default RE: Screamin Demon Tranny?? (Long)
It sounds to me like you guys have your ducks in a row and already know what direction tolook in?
The only other thing I might add is that I have heard that AM TOB"s can be crap out of the box, but that would likely go away w/the pedal depressed, or at least make a different sound(s.)
The PB is certainly another possibility.
How about the input shaft bearing? Since the tranny was disturbed (removed, drained, refilled, reinstalled) there"s a chanceit didn"t "like" something about that process.
Old Nov 2, 2008 | 09:13 AM
Yeah these are really simple engines, not to many things it could be
Im kinda iffy on the TOB being the Problem, Excedy is a good company havent really heard any problems about them, Now SPEC thats a differnt story.
But there is no change in sound if engaged or disengaged.
Its just a weird sound to come from a tranny, sounds like a slipping belt (but its not)
I thought it could be the Input shaft bearing but its too loud to be internal,
Old Nov 2, 2008 | 11:49 AM
wsoape281's Avatar
sounds like you could have the clutch disc mounted backwards.
Old Nov 2, 2008 | 12:16 PM
hmmm now that could be possible.... I talked with him and he said he was very careful in installing it he followed all the pics and instrction that came with the kit
Old Nov 2, 2008 | 02:17 PM
wsoape281's Avatar
a screaming tranny only really means one thing, you need to pull it apart again. you will only do more and more damage if you continue to start it up.
Old Nov 2, 2008 | 02:46 PM
ORIGINAL: wsoape281
Thats the plan were gonna pull the tranny, Disassemble the clutch, inspect, grease, and reinstall new pilot bearing, and maybe a TOB, just hoping some body could help pin point or if anyone encountered this before.
Old Nov 2, 2008 | 07:45 PM
wsoape281's Avatar
the only time that i ever had a screaming tranny was when my buddy stuck the clutch brake backwards. i have heard grinding when a pilot bearing was going, but that usually just happens when you put it in gear and release to engage the gear.
Old Nov 4, 2008 | 02:12 PM
It"s been a very, VERY long time, so long that I forgot.Back in my early days of car repairs, my friend"s too, we did that once and like Wes says, it screamed until we pulled the tranny and reversed the clutch disk.
UseYourNoggin
Aug 6, 2015 06:59 PM
b6t323
Mar 28, 2013 12:10 PM
lawdog
Nov 16, 2009 05:23 PM
EthereaL
Mar 5, 2008 08:24 PM
ktsnos82
Jul 29, 2005 12:00 PM
