injector pulse
Like for example, the mazda fuel injector duty cycle (IDC) is the percentage of time the injector is supplied with power. The time during which the injector is powered (or activated) is called the injector pulse width (IPW). During normal engine operation, the fuel injector fires once during the four strokes of the Otto cycle, which last for 2 revolutions of the engine. As an example, at 3000 rpm it takes 0.040 seconds or 40 milliseconds (ms) for the engine to complete 2 revolutions (3000 rpm divided by 60 equals 50 revs per second; invert to get 0.02 sec per rev or 0.04 second for 2 revs). At 6000 rpm it takes 20 ms for two revolutions. If a fuel injector is activated for 15 ms (the IPW) at 3000 rpm the duty cycle is 37.5% (15 ms/40 ms), or rpm times IPW divided by 1200 equals IDC in percent. If an injector is powered for 15 ms at 6000 rpm, then IDC is 75% (15 ms/20 ms). If you know the engine speed (rpm) and the IPW (dataloggers can provide this information), then it is easy to calculate the IDC.
