HELP ME I LOVE MY CAR AND ITS NEEDS HELP
Old Aug 24, 2007 | 06:57 PM
perkinsbl's Avatar
Default HELP ME I LOVE MY CAR AND ITS NEEDS HELP
Ok, so my 1984 rx-7 12A was running, i just bought it as my first car. I've looked over the manual and understand the only main difference but here's what's goin on, i was driving, its a manual, it stalled but i didn't stall it. I tried to re start it but it wouldn't turn over. i tried repeatedly and waited. Eventually it turned over and started. once it turned over it would start alright on the drive home this happened three times, it was pretty bad. Before i got where i was goin, last time it stalled, wouldn't start so i tried jumping it with no help, got it towed... and since have got the starter tested, at a shop against resistence, so thats fine. once i knew that wasn't it i looked at the ignition system. I found that one of my two coils had water residue with a rust tint, corrosion so i replaced that and the wire. i tried starting it right after didn't turn over, i was hella pissed lol but i waited and tried again and it started, at this point it didn't wanna idle well and there was a rattle so once i could i got closer i think its in the engine, any ideas there? Also after i let it idle to low and it stalled it either was a pain to start or plain wouldn't. But it turns over now,i'm not sure if i can trust it because after i replaced it it didn't fix it right away. I've used a battery jumper and starting fluid, none of these really make it start like it consistantly or even together. Lastly as i would drive, accelerate i'd be blowing huge light blue clouds of blue smoke, O-rings? I've gotta go into the engine but before i'd like it to start consistantly so HELP ME PLEASE!!...I don't know i love breakin loose with my car listenin to my custom system , also its my only car, first car and need it for transportation, so any info is greatly apprecaited!
Old Aug 26, 2007 | 12:11 PM
hixx's Avatar
Default RE: HELP ME I LOVE MY CAR AND ITS NEEDS HELP
Sounds like the ignition switch contacts as far as the starter issue goes. Pretty cheap and they are a common problem. The blue smoke is oil. Possibly your oil metering pump is hung wide open. If not then it has blown an internal seal.
Old Oct 4, 2007 | 09:45 AM
sunshineFC's Avatar
Do a compression test.
-a
richardvan1
Nov 11, 2010 06:27 PM
Herblenny
Oct 23, 2008 01:05 PM
Herblenny
Sep 16, 2008 10:10 AM
Billfrompa
Jun 17, 2006 12:56 AM
the_gray_mazda6
May 5, 2006 02:44 AM
