Anyone with a first gen Rx7
ok i just put tags on my 1982 mazda rx7 and its 5 speed.
got a small problem. I was driving it down the road and it got hard to put in gear. after i got it in gear i couldnt get it to go to the next gear at all. i need help. if anyone has had the same problem please tell me what it is. SOMEONE PLEASE HELP ME
I know enough about cylinder engines...i have a question i just got an 85 RX-7 13b FI...i want to know everything about rotaries... i'm also having a problem with the car. I'm told that the reason is its because the engine has been seating for so long and has lost compression, and that its the apex seals. I'm getting it rebuilt from someone on craigslist. for 800. He claims to be doing a basic rebuilt. I need advice whether i should go do it...heres the link to his ad..he also told me i had a one year warranty for the rebuilt. I want to know if its a good deal?..http://losangeles.craigslist.org/ant/pts/567225116.html
I have an 83, a similar thing happened to me. The slave master cylinder on the clutch assembly went. You can still shift into and out of gear but you have to rev match in order to not use the clutch and getting into first gear requires either a push or a small hill
ORIGINAL: RotorMotorRX7
my 83 did that, (i think its what you were talking about) it shifted hard for a while, then it went into gear and wouldnt come out, you can move the shifter, but it does nothing, thats either a broken shift linkage, or broken shift fork, either way itll basically be a new transmission to fix it, but if you can still shift it, it could be worn syncros, which is the same fix, or it could be a bad clutch cylinder, whether master or slave, also a problem mine had, also check the hydraulic lines for your clutch, sometimes with that kind of age they rot, then you cant disengage the clutch...
