Window
Old Nov 8, 2008 | 05:55 PM
protegeven's Avatar
Default Window
Hi,
My 99 protege's passenger side window is not working. It used to be working fine, but before it went out, in the last stages, I had to pull hard the switch to get it closed or open. Fortunately it stopped working in the closed state. Since then, there is no movement at all.
What could be the reason? And can I fix it myself?
Please let me know,
thanks
Ven
Old Nov 9, 2008 | 02:06 PM
wsoape281's Avatar
Default RE: Window
sounds like it may just be a short in the switch. the switches are easy to replace, but kind of hard to get to. you need to pull the door panel to get to it.
Old Nov 10, 2008 | 03:29 PM
protegeven's Avatar
Default RE: Window
Hi Wsoape281,
thanks for your reply. By any chance do you happened to have the diagram/instructions for removing the door panel. If so, could you please let me know it? Or else, could you point me to a place to get them?
thanks again,
Ven
Old Nov 11, 2008 | 07:42 AM
icspots's Avatar
Default RE: Window
If it's anything like the door panel on the 3 then there are probably a few screws to remove, then there are tension clips around the sides/bottom with a few in the middle..... pull on the panel to release those. Then the whole thing slides up to disengage from the window channel. From there you have access to disconnect the harnesses going to the panel for the switches.
Old Nov 11, 2008 | 06:42 PM
wsoape281's Avatar
Default RE: Window
that's pretty much it. just be careful when you think that you have all of the screws out, there is usually one hanging on.
Old Nov 17, 2008 | 07:42 PM
proteg321's Avatar
Default RE: Window
i have the 00 prot. should be the same door panel....
1-at the top left corner under a cap there is a screw
2-inner door handle 1 screw
3-at the top of the arm rest in a cavity 1 screw
4-at the bottom of the arm rest 2 screws ( it is held there by clips just pull should come out)
5-behind the arm rest (once out) should be 1 or 2 screws....dnt remeber
the panel should be held only by clips now just pull gently and it will get undone(when all the clips are undone pull the panel upwards)
might be a little different...im not sure since u have power w/L.... the arm rest might be different but if u look closely u'll find them....
Old Nov 18, 2008 | 05:41 PM
protegeven's Avatar
Default RE: Window
Thanks a lot guys. I am going to try opening it this weekend. I will update you if I find somthing specific.
thanks again.
HerrKaLeun
Aug 4, 2013 08:34 PM
tessie2002
Mar 28, 2007 05:01 PM
the_gray_mazda6
Mar 15, 2007 09:26 PM
ginman999
Jun 27, 2005 01:34 AM
maynard22
Apr 13, 2005 03:12 PM
