Sea Foam
Old Mar 24, 2007 | 09:58 PM
Dino1956's Avatar
Default Sea Foam
What's the deal with Sea Foam ? It looks like you can use it in Gas Tank, Intake, etc...Any comments or stories welcomed. Thanks.
Old Mar 24, 2007 | 11:27 PM
dr4g0n3's Avatar
Default RE: Sea Foam
you mean the foam used for making dashes, sub boxes and custom areas?
Old Mar 25, 2007 | 02:26 PM
Dino1956's Avatar
No. Sea Foam Motor Treatment. It's an liquid additive for your Engine.
Old Mar 25, 2007 | 04:09 PM
dr4g0n3's Avatar
ahhh ok. not sure about it then.
was gonna see if you needed help fabing something. its pretty easy for me.
Old Jun 5, 2007 | 09:08 PM
2oo2's Avatar
I realize this is an old thread , but anyways....
I was introduced to this stuff by one of my buddies that works at autozone. I got a ticket for my inspection being expired and to make it worse, now we have to get emision tests done. Well they won't even hook up your vehicle if the CEL is on. On my 99 ford ranger the CEL was on. I had had the same code before when I had to replace my O2 sensors ("lean mixture"I think). Anyways I had a court date the next day and didn't have time to change spark plugs or O2 sensors or anything. So I bought a can of sea foam and poured half into the gas tank, and put the other half in a spray bottle and sprayed right into the throttle body. Drove it back to advaced and had them reset the CEL. Next day it passed the emissions test and the CEL stayed off for about a year (until just before my next inspection). I did it again with the same results. I think you can also add it to your oil, but I'm not sure.
Well hope this helps some.
iHeartMazda
Aug 2, 2010 07:59 PM
virgin1
Nov 15, 2009 06:05 AM
2000grnS
Feb 17, 2008 12:01 AM
rooster2
Apr 23, 2007 06:49 PM
