Revs drop to 0 when putting in clutch or putting in neutral only when engines warm
Old Feb 14, 2019 | 08:35 AM
Keegs's Avatar
Default Revs drop to 0 when putting in clutch or putting in neutral only when engines warm
I have a 2003 Mazdaspeed Protege with a turbo. It has a HKS Blowoff-Valve and Tial Wastegate with a boost controller. For the boost gauge I tapped into the FPR line. When I’m driving and I press in the clutch to shift or put it in neutral the revs will drop to 0. This issue only happens when the engine is warm. I’ve already replaced the MAF sensor, EGR Valve, crank position sensor and the fuel pump, but I still have this issue. Also if I floor the gas pedal sometimes it will stick, I already cleaned the throttle body and it still happens. Any ideas on what this could be?
crouchy1984
May 23, 2014 05:42 AM
LESLIEPINKY
Jul 6, 2011 03:08 PM
bethany626
Apr 11, 2011 01:48 PM
RoniisH
Mar 25, 2010 09:48 AM
Mel
Jan 24, 2009 06:00 PM
