Removing Quarterpanel?
girlfriend has a 95' protege. How do i remove the front right quarter panel so i can bang out a major dent?
Also is there a way to clean the headlights (taking them apart) and remove the fog on the plastic without destroying them?
thanks!
thanks!
To remove the front fender, you have to remove the front bumber cover first. There are 2 screws on each side, and the lights unplug.
Then you will find two screws at the top of the fender(one is hidden near the marker light), one behind the side marker, one behind where the bumper cover was, one at the very bottom, behind the wheel, and (this one is a bitch) behind the A-pillar that you can only see with the door open.
As for the headlights, the ending option for you after wasting your cash on all the cleaning agents that do not work, (like I did) is to get some new aftermarket headlight assemblies. DEPO makes some that are $100 each.
Rooster
Dec 2, 2004 09:37 PM
