Quick Question regarding Ignition Coil!
Old Sep 20, 2013 | 11:28 PM
warrior86's Avatar
Default Quick Question regarding Ignition Coil!
Hopefully this isn’t too confusing and sorry if my wording is off, but trying to explain it the best I could.
I added pictures to make things a bit more clear.
Car: 2003 Mazda Protege5; 2.0 Liter… 4 Cylinder
This is my mom's car and she got a code that references a few different items, once of which was the ignition coils. I did some research and some people say it is common on these cars that they go bad and need changing. Luckily it is around the tune up time for my mom’s car so I will be doing spark plugs, ignition coil, pcv valve, wiper blades, stuff like that. But regarding the ignition coils. I was planning on buying the full coil (need two of them for this car) See the part I am talking about in the picture attached that is labeled (Picture 1).
However, I bought a package since I needed the other 2 coil boots ( I believe they are called) that have wires coming off them (See Picture 2) that connect to the main ignition coil piece (Again, Picture 1), but they came with 2 extra pieces which is what makes up the lower half of the main ignition coil.
I was just wondering if in the scheme of things when it comes to ignition coil giving problems, does the upper half of them where the wire harnesses are located go bad, or the 2 extra pieces they included in the package I got which just need to be swapped out go bad more? This way it will save me like $60 from having to buy the entire thing, instead of me just replacing the bottom portion.
In Picture 3, it shows in the red circle how it connects the top and bottom part, with the spring in the middle, so it doesn’t look like a big deal at all.
Would be awesome to have any feedback. Thanks a bunch.
Old Sep 21, 2013 | 08:56 AM
Replace everything for piece of mind and knowing it was done right.
Don't know specific problem for that P.O.S.
Old Sep 21, 2013 | 12:46 PM
tanprotege's Avatar
I think Noggin is right. I follow the Lincoln LS forum and they have always trouble with Coil On Plugs. Their recommendation is to replace all plugs after gapping them right and replace all COPs at the same time.
This design is a bit different in that one coil is firing 2 plugs. To me this is an additional reason to replace all 4 plugs. Make sure the gap is right, and replace all coil packs and wires together.
Otherwise you will be under the hood again and again.
Hellohibonjour
Apr 10, 2015 08:45 AM
littleman626
Jul 27, 2011 02:42 PM
Ach3r0n
Jul 31, 2009 11:27 PM
successful3012
May 12, 2008 05:46 PM
LA Woman
Aug 25, 2005 07:57 PM
