PS pump tensioner issue / 2000 Protege
Hey guys,
So I was trying to replace my alternator belt the other week, and in the process I was trying to loosen the slide tensioner on the power steering pump (the one just below the pulley). I guess it had seized up or something, and in the process I stripped the bolt head. Is there any other way of removing/replacing the power steering pump belt in order to access the alternator belt? My first thought was possibly the crankshaft pulley, but I was hoping that there was an easier way. |
In the end you need to get that stripped bolt out anyway. Without that you can't adjust the belt tension.
One of the best penetrating oil concoctions is 50:50 acetone and tranny fluid. Teh acetone really gets into crevices and carries the oil with it. The acetone evaporates, the oil stays. Not a nice situation. I once had to get a special stud removed from a Chevy Cavalier. It cost me about $200 in the early 90's. |
1 Attachment(s)
(Post 144459)
One of the best penetrating oil concoctions is 50:50 acetone and tranny fluid. Teh acetone really gets into crevices and carries the oil with it. The acetone evaporates, the oil stays. Not a nice situation. I once had to get a special stud removed from a Chevy Cavalier. It cost me about $200 in the early 90's. Attachment 8793 |
I looked at the very same diagram and I know how tight it is there. If there is anything left on that bolt head try the penetrating oil and vise grips.
It probably won't work. Then remove A and C and get an angle grinder or die grinder and cut off the head of B to remove the tensioner bracket. Now you should be able to push the pump out of the way and get a vise grip on the stump that's left. If that doesn't work you may need to weld a nut on it. I would give that job to a shop that carries insurance. Best of luck! I just looked at it one more time. You may be able to get away without that bolt. I know that A and C have a pretty good hold on the bracket. So you can try cutting the head off B. Adjust tension with D and tighten A and C (but don't strip those!). For good measure check often and keep your fingers crossed. Also keep soaking it with penetrating oil and try getting it out later. |
