P0117 and P0304
Old Mar 24, 2024 | 09:03 AM
Saudade's Avatar
Default P0117 and P0304
Apologies in advanced for the long post.
TL;DR
Son and his P5 stranded in rain with overheat. Topped off radiator and overflow. Take surface streets home. New radiator cap seems to have fixed it. Engine runs well, no more codes. See below for more details.
What temp does your P5 normally run at?
<verbose mode/on>
Son is on his way home yesterday during a big rainstorm. He was about 30 minutes out in heavy traffic when his CEL came on and coolant temps gauge pegged rather suddenly. He managed to limp off the freeway and into a nearby strip mall parking lot. Calls me, tells me what happened. He carries a cheap code reader and told me the 2 codes. Since one related to coolant, he checked the overflow bottle and it was empty. The Temp warning light never came on. OK, so far not good.
So I pack up some tools, my better scanner and about 1.5 gals (6 liters) of coolant and head out. It's still raining when I get there but the car has cooled off. Pop the rad cap and I see no coolant. Go to top off the rad and it takes nearly 2 quarts. Still raining out. Start the engine, seems to run fine. Continue topping off the rad, takes about another 1/2 quart. Let it run for a few minutes, still getting some bubbles in the rad. So we decide to put the cap back on it, top off the overflow, stick to surface streets and head home. I drove it and kept my scanner connected to watch the live data. I cleared the codes before we left.. My son followed me in my car. About halfway home, the rain stopped, sun came out. I took it as a good sign. Managed to get home without further incident.
One thing to note was the coolant temp indicated on the dash stayed around the middle of the range. My scanner reported temps around 224-228, reaching 230 for a brief moment at a traffic light. I almost pulled over to call a tow but the light turned green and as we moved the engine cooled a bit.
So we get home, I pop the hood with the engine still running, and I can hear and see the coolant bubbling in the over flow tank. Dang!! After cooling down I pull the radiator cap and the radiator's still full. I should note that once the rain stopped and we got closer to home, my son did not observe any smoke coming out the exhaust.
At this point however, I fear he may have blown a head gasket. While I do have a compression tester and a leak down tester, I decide to do the block test with the special liquid. Since I don't have one, I'll get "rent" one from my local auto parts store. While I'm there I'll get a new radiator cap as I never reuse one that's overheated.
So off to the first autoparts store. I checked online first to see if they had them in stock (they did). Parts guy gets the cap but reports the tester is not there. OK, so I grab the cap and head home. Turns out the cap doesn't fit, it's too small. Go back online and discover caps for autos are different from manuals. Mine's an auto, cap was for manual. So I check another store (different company), see they have the right cap in stock and the block tester. So off again with my old cap in hand. This time it's the right one, but the block tester is not there. The do have the radiator pressure tester (the hand pump) so I "rent" it.
Get home and to my surprise, none of the adapters for the pressure tester fit. I admit, I laughed a bit. So with the rad topped off and the overflow filled, I started the engine and left it warm up with my scanner attached in live data. I carefully watched as the temp climbed. With an occasional 2000-3000 rpm blip, the engine temp stabilizes at around 212F. The electric fan kicks on too. Also, there are no codes, in fact the drive home was enough to reset all the readiness monitors.
So I climb in and drive around the local streets, just in case. Car runs fine. Temps touched 213F once but remained pretty much at 212F with an occasional drop below 210F. Got back home, popped the hood, looked at the overflow bottle and there's no bubbling, the level looks good. Shut it down, left hood open to cool down. Came back out, coolant overflow level still good. Took rad cap off and it's still full.
Hmmmm.... Good sign?
While I may order the block tester online and still do a compression/leak down test, that won't happen today.
So at face value, it appears the issue was a bad rad cap? It lost pressure, then lost coolant, the low coolant triggered the P0117 code. The bubbling coolant in the overflow was just the rad boiling over due to the bad cap? While possible the high temp caused the misfire, his P5 does occasionally trigger the same P0304 when he drives in heavy rain. It still runs OK, and the CEL usually goes out once he's out of the rain. He changed the coils out last year (while he live in another state) so I think the misfire is more coincidental to the rain and not the overheat. Going to do some more local driving with it today (local errands like returning the wrong cap and tester) with my scanner hooked up.
At what temp does your P5 run? FSM indicates 212F is thermostat full open.
Any opinions on the rad cap being the cause of the problem? Given all other live data looks good and no codes after about 30 miles of driving (just enough to reset readiness monitors) and engine runs well, do you think we're OK? The other tests will have to wait until later this week. We do have a spare vehicle him to use while we figure this one out.
TIA
Old Mar 24, 2024 | 02:20 PM
Saudade's Avatar
Well, so far so good.
Ran a few errands with it this morning. Back to parts store #1 to return cap. No issues. Temp remained around 212.
Then back home to get tester and return to store #2. Same results.
Oil looks good. Overflow tank is “full”, no bubbles. Radiator is still full. Son took it out for his own errand locally afterwards. Says it runs like always.
Still plan to do block test and leak down just be be sure no other damage occurred. Going to order some plugs to replace while I have them out.
Old Apr 7, 2024 | 03:13 PM
Saudade's Avatar
So just an update. P5's been running well. Did a drain and fill on the coolant. Drove around town to get it hot and check for leaks. Ran with my scanner on never got above 226F when I let it idle for about 20 minutes. Both fans came on. Ran around 215F while moving.
FSM say the ECT PID should be between 180-234F (82-112C) at full temp. Dash gauge needle is midway.
Old Apr 9, 2024 | 01:01 PM
Saudade's Avatar
Another update.
We've put another 20 or so miles on the P5 over the past few days and I noticed the coolant level in the overflow tank was pretty low so I picked up a block tester. Mind you that it runs well and temps never exceeded 220-ish.
So drove it around for a few miles and let it idle to ensure the fans were on and it was up to full temp. While still idling, there were no bubbles in the tank. Used the block tester and there was no change in the color of the test fluid. I gave it about a dozen pumps.
Let it cool enough to release the cap and then tested at the radiator. Again, no color change after a dozen or so pumps. Perhaps I didn't fully purge all the air after the drain and fill and it took a few more heat/cool cycles to fully "burp" the system. I'll test it again in a few days after we log a few more miles.
Old Apr 19, 2024 | 05:05 PM
Saudade's Avatar
So 10 more days and about another 50 miles and it still looks good. Coolant level in the overflow is good. Still right at tank seam (full mark) when cold and just shy of top of the word FULL when hot.
I'm gonna call this closed. If other issues develop, I'll start a new thread.
Sr22
Oct 21, 2023 02:56 AM
emiilyyb
Jul 13, 2022 10:15 PM
stephscape
Nov 4, 2017 05:30 PM
thekrayze
Sep 14, 2015 05:54 PM
jucs
Apr 27, 2014 05:28 PM
