Mechanic HELP 1997 Protege not starting
Old Dec 21, 2010 | 08:57 AM
  #21
rgautier2003's Avatar
Originally Posted by rockoe
seems the fuel would shut off after cranking and it not start.plugs shouldnt get that wet that fast.maybe fuel regulator or something.do you hear the pump?does it keep running while your NOT turning it over? a scanner is a must.points to a system to check.if the scanner says MAP or EGR bla bla bla,im sure you know not to just buy an EGR valve.done that one. im guessing its fuel regulation related.im guessing the check engine light is on?
I can not hear the fuel pump but have gas up front with no issue, but hear a buzzing under the hood with the key in the ON position.
Even with a little fuel I should still get some type of putt right? And im getting fuel doesnt seem excessive until I keep cranking on it. Thats why im not thinking its fuel related.
I rented a cheapo scanner and will look tonight to see what it says, fingers crossed :/
Check engine light has been on for the last 50k+ miles, when I last scanned it, it pointed to oxygen sensor, replaced sensor and still came on so rode since then with no issues. Im hoping a new code is in tonight
Im not familiar with EGR/Map why not change, not critical to starting??
Old Dec 21, 2010 | 08:09 PM
  #22
ok- I screwed up the other day by disconnecting the positive battery cable b/c the scanner does not pick up any failure DTC codes. aww...
Old Dec 22, 2010 | 05:48 PM
  #23
rockoe's Avatar
they are but if a avcume hose is loose or a wire comes loose,the code will come up for a sensor but its because something else came loose but the sensor is still good. the code tells you what SYSTEM isnt working correctly. an oxyen sensor code could mean alot of things fuel related but wont be the acual sensor. i had an EGR code on my 96 blazer so i spent 120 buks on a new EGR valve and it still ran like crap.turns out,chunks of carbon had come loose and held the valve open, i cleaned the old one and put it back in and SEA FOAMED it every year and runs great.im out of ideas.hard to tell when your not there.
Old Dec 23, 2010 | 01:30 PM
  #24
Update OK- had to take to precision tune since I was at a total loss on what to check next...
Compression is 20psi on 2 and supposedly the other 2 cylinders were 10psi. Looks like car is garbage. I wonder if trying to start when it was frozen could have caused this? I also know the car burned oil and sometimes it got right below the low mark a couple times (figuring this caused it)
Greg6721
Feb 21, 2020 01:50 AM
nkeyornelas
Jul 21, 2011 11:30 AM
kenfinkel
Jan 18, 2010 08:45 PM
irongiant369
Dec 18, 2008 11:26 PM
NEED HELP BADDLY
Jul 11, 2008 07:10 PM
