Mechanic HELP 1997 Protege not starting
Old Dec 19, 2010 | 07:44 PM
rgautier2003's Avatar
Will a bad cam or crank sensor stop the car from even trying to fire?
Old Dec 20, 2010 | 04:58 AM
North42g's Avatar
DEAD BATTERY.
Check your voltage across pos & neg terminals. Needs 12.65 to start. If it is not get a new one.
"it wouldn't start after a -30 degree storm."
Old Dec 20, 2010 | 05:30 AM
North42g's Avatar
Originally Posted by rgautier2003
I know i'm frustrated also since if something would just point to an issue it would be a lot easier err...
thanks a lot for trying to help me!!!
There could be more DTC's that you don't know about.
ALSO: Go back to Basic's;Air, Fuel, Spark.
Battery.
Frozen Fuel Lines.
Old Dec 20, 2010 | 05:38 AM
North42g's Avatar
Arrow
Check that your Distributor is working as designed.
Test for Battery Voltage on the WHITE/RED wires & BLACK/WHITE wires @ Distributor.
Test for ground on the BLACK/LIGHT GREEN wires & BLACK/PINK wires @ Distributor.
ALSO: Mazda has issued TSB# 002/98: Worn intakes vavles; engine will not start in cooler weather below 40 degrees Fahrenheit due to worn intake valves.The engine will not start, when its cold, unless you give it gas. It acts loaded up, then cleared out and runs. You need to push & hold the accelerator pedal to the floor, while cranking, to clear it out, then it should run.
Check the engine compression and cylinder leakage. If there is leakage past the valves, verify the cam timing is correct. If the problem is not cam timing, then inspect for worn intake valves.
Old Dec 20, 2010 | 05:54 AM
North42g's Avatar
Exclamation
What model vehicle is this any ways!!?? Protege Dx, Es, Lx ?? 1.5L? 1.8L?
Mazda Engine TSB #002/98 addresses low compression problems caused by worn intake valves. {cold weather can amplify this effect}
Good-Luck.
Last edited by North42g; Dec 20, 2010 at 05:58 AM. Reason: Added pertanent information
Old Dec 20, 2010 | 09:54 AM
Good-Luck.
Engine is 1.5 Dx
Old Dec 20, 2010 | 09:55 AM
Battery.
Frozen Fuel Lines.
I am going to get a scanner today to hopefully help, fingers crossed
Old Dec 20, 2010 | 09:57 AM
DEAD BATTERY.
I have recharged multiple ttimes and it holds a charge is full. Battery is 1 yr old. It has omph to turn over and sounds strong.
Old Dec 20, 2010 | 10:01 AM
Battery.
Frozen Fuel Lines.
what types of air things should I check for? Any main sensors that would prevent it from trying to fire? I cleaned mass sensor, hose is solid no holes/crack. I looked at all hoses on top of engine and all look good.
Old Dec 21, 2010 | 08:02 AM
rockoe's Avatar
Default i just like saying "fuel pump relay"
Rockoe-im getting gas inside the plug holes and after continuing to crank it gets flooded. Also after airing it out and spraying starting fluid in the plug holes and in the air intake, it wont even try to start whatsoever but does continue to crank. So id think the fuel side is ok
seems the fuel would shut off after cranking and it not start.plugs shouldnt get that wet that fast.maybe fuel regulator or something.do you hear the pump?does it keep running while your NOT turning it over? a scanner is a must.points to a system to check.if the scanner says MAP or EGR bla bla bla,im sure you know not to just buy an EGR valve.done that one. im guessing its fuel regulation related.im guessing the check engine light is on?
