Just got my '99 Protege!
Old Nov 27, 2007 | 10:36 PM
Clob's Avatar
Default Just got my '99 Protege!
Its a '99 lx 1.6L. 91k on the odometer. I just got it from Carmax (not a bad bunch) and got a 3 yeak 36k mile term on anything thats not rubber. The engine sounds good and has power. It didnt seem unusually weak.
Anyways. It does have the rattle at idle problem. I'm looking into the motor mounts and I'll check to see if the fuel filter was replaced. I have 30 day free waranty on it and I want to find anything wrong with it. What should I be checking?
Thanks. [8D]
Old Nov 28, 2007 | 05:15 AM
Clob's Avatar
Default RE: Just got my '99 Protege!
I knoticed that the shift to and from Reverse or Drive is seems a bit harsh. Is this normal?
Old Nov 28, 2007 | 10:28 PM
MazdaES's Avatar
Ford transmissions are not the smoothest. Also have them check the Idle Air control valve.
Old Dec 7, 2007 | 10:25 PM
downtube's Avatar
1.vacuum leaks
2. clogged EGR passages or stuck EGR valve
3. dirty MAF sensor
Old Dec 10, 2007 | 06:16 PM
00protegeracer's Avatar
i got a 00 lx and im gettin my egr valves cleaned and i should have my car back by tomorrow ( hopefully) ill be able to tell u if thats what is causing it cuz im having the same problem. are u planning to keep it stock or u gonna make it a lil beast?
LS7 Thunder
Nov 25, 2006 04:04 AM
LS7 Thunder
Sep 2, 2005 12:28 AM
epheterson
Aug 1, 2005 02:44 AM
riuster
Jun 23, 2005 06:52 PM
UkWildKitty
Aug 17, 2004 02:40 AM
