Intermittent clutch slip?
Old Aug 17, 2015 | 06:23 PM
texastexas's Avatar
Arrow Intermittent clutch slip?
My 02 Protege5 has gone several months without any noticeable clutch slipping.
It has slipped before, on occasion, in 4th & 5th gears. But, it has been several months. Furthermore, in those interim months, I've been pulling a small and light sailboat with the thing! It's small and light, but I know it's a strain on the entire drive system.
So, I'm confused about why this clutch slip comes and goes.
Could it be a cylinder issue instead? Or should I just buck up and pay for the clutch swap?
I'm supposed to drive to NC and back, 3000 miles, in two weeks!
Old Aug 18, 2015 | 03:15 AM
Do you have a cable operated or hydraulic operated clutch?
Check the clutch free play & pedal free play.
Towing a trailer does put extra load on your clutch, which will cause an increase in heat, heat is not a clutches best friend. A increase in heat will decrease the friction of the clutch disc causing slippage.
I suggest taking your car to a trusted Mechanic or clutch specialist for inspection.
It's not looking good.
Old Aug 18, 2015 | 11:12 AM
texastexas's Avatar
That's partially why I'm so confused. It didn't slip at all while I was pulling the trailer with 3 people in the car, a bunch of gear, and 102 deg F outside to boot!
Shame on me for attempting such a thing, I suppose. But, the clutch performed 100% perfect during that abuse, so why should it slip for 10 minutes during a drive to the grocery store yesterday?
Does that reveal anything about the nature of the problem?
Old Sep 10, 2015 | 02:03 PM
Juanky's Avatar
have you noticed any oil leaks? if the back crankshaft oil seal leaks, it can get the clutch wet with some oil and slip. check the clutch/pedal adjustment, it might help. that adjustment is not complicated but makes a big difference.
Old Sep 10, 2015 | 02:40 PM
Heritage Mazda's Avatar
Former Sponsor
Generally clutches don't slip intermittently unless they are out of adjustment. Some things like tire slippage can sometimes seem like a faulty clutch.
audioinmotioninc
Jan 23, 2019 10:13 AM
ryder055
May 13, 2015 02:42 PM
MazdaSTL
Dec 1, 2009 05:26 PM
MazdaSTL
Dec 1, 2009 05:23 PM
show_stopper
Feb 13, 2008 07:34 PM
