Hissing Noise After Shutting Off Engine
Old Feb 21, 2009 | 12:38 PM
protegedon's Avatar
Question Hissing Noise After Shutting Off Engine
Have an 03 Protege DX, non-turbo. Lately I've noticed a hissing sound coming from under the hood right after shutting the engine of. Could this be related to the fuel injection? A leaking regulator valve perhaps? Car seems to start and run OK. Once in a while idles a little rough. Thanks.
Old Feb 21, 2009 | 06:47 PM
wsoape281's Avatar
it is probably just the a/c condenser blowing off the pressure when you turn off the car.
Old Mar 14, 2009 | 04:28 PM
copierman's Avatar
have you check ed cooling system? when car is turned off , the pressure starts to buld in cooling system. water/antifreeze could be returning to overflow reservor or ......... leaking on to a hot engine !! lift the hood and find the noise , soon!
Old Mar 15, 2009 | 06:30 PM
04yamaha's Avatar
could be a vacum leak they will hiss for about 4 second after you shut the motor off
Old Mar 28, 2009 | 11:33 PM
protegedon's Avatar
Don't think it is AC, as does it when I'm not using it. No water leak or coolant overflow either. Probably vacuum leak. I hear the sound when engine is running with hood up, but can't tell where it is coming from. Will have to have checked out when I get drive belts replaced. Thanks all.
Old Mar 29, 2009 | 09:41 AM
oldeng's Avatar
Get a 2 ft.piece of tubing and improvise a stethoscope so you can pinpoint the noise.
The duration of it suggests it might be the pollution control evap loop returning vapor to the charcoal cannister. There might not even be a leak at all, just the "heavy breathing" of the valve. If you look on the underside of the hood you should see the "map" of the evap loop plumbing.
Old Apr 5, 2011 | 08:14 AM
protegedon's Avatar
Default Still have symptom, maybe normal?
Hey folks,
Been a long time. Still have the same symptom, but think it must be normal. My mechanic discovered a cracked intake hose that I replaced, but it had nothing to do with this issue. Car performs fine, so I'm thinking this is normal. Just a hissing valve somewhere. Might try the tubing trick if curiosity gets the best of me. If anyone has any other suggestions or insight, would be interested in reading it. Thanks.
Old Nov 10, 2012 | 09:50 AM
Stoyan's Avatar
I have the same problem with my 03 Protege. The hissing noise comes from the front left side of the engine, somewhere by the ac compressor.
chall1993
Jun 23, 2014 08:21 PM
Mrfresh352
Feb 2, 2012 12:01 PM
SILVERFOX205
Nov 10, 2011 10:40 AM
kingkleks
Apr 16, 2008 10:32 AM
GoT_DeaD
Nov 20, 2006 08:26 PM
