Help with suspension.
I have a 2000 Protege 1.6L
i love the car but the ride is a little rough and the car swings from side to side when you turn. I would love to make the ride as smooth as possible and make it so that the car turns when I turn and not swing when I turn.
What should I do to my car? What do I need to buy?
Thanks in advanced.
Thanks in advanced.
end-links might be blown. they go out on your generation all of the time. go with an after market end-link and you won't have an issue again.
http://www.corksport.com/awr-protege...03-prot-g.html
they will also give you some adjustment on the suspension. a rear strut brace might not be a bad idea either.
http://www.corksport.com/corksport-r...rut-bar-1.html
This will be better than new if you go with an adjustable end-link. You can pre-load the suspension to make it a little tighter into the corners. From there, you can set the toe to get a little more adjustment out of it.
