have a bad rust spot in trunk where rusted jack was
Old Aug 15, 2007 | 11:44 PM
spiderpig's Avatar
Default have a bad rust spot in trunk where rusted jack was
what metal would be a good choice 2 weld in 2 cover it and is this a common problem on rust belt bg's? seems 2 me that because theres a little bit of a dip 4 the jack that it's preatty common any help is awesome thanks!
Old Aug 16, 2007 | 07:07 AM
sstlaure's Avatar
Default RE: have a bad rust spot in trunk where rusted jack was
I'd hit the rust with a steel wire brush, then paint over it with a product called picklex. It will seal out the oxygen to the rust and actually change the properties of the rust so that it doesn't get any worse.
I'd try and figure out how water is getting into your trunk. It should be bone dry in there if all of your seals are doing their job.
Old Aug 16, 2007 | 11:59 PM
spiderpig's Avatar
well i also got water in the drivers side front and back just found out about it 2day cause 1st time its rained since ive had car. but it wasnt 2 bad just something 2 **** me off
Erin80
Sep 14, 2011 10:23 AM
Erockshacore
Apr 2, 2009 10:32 AM
UrbanmanUSA
Jul 21, 2007 11:09 AM
sublime12
Dec 29, 2006 11:32 PM
fourbanger
Nov 11, 2005 08:23 PM
