Gear shift issue
Old Apr 7, 2006 | 07:51 PM
Bear's Avatar
Default Gear shift issue
HI guys,
Glad to find you here...
Now, my issue: I have a 2002 Protege LX, 2.0, manual, 76000 km.
I just got the car 3 months ago, at around 72 000 km.
Since then, I didn't really do long trips, but I noticed that if I run the car more than ... lets say 40 minutes (highway or not)
changing gears becomes difficult. I mean the car is getting into gears with no problems, but the stick is moving quite difficult
and you can hear also a " screeech" sound. The problem dissapears if the car is stopped for about an hour...
Anyone has any hint why this is happening?
Thanks guys
Old Apr 7, 2006 | 08:01 PM
Bear's Avatar
Default RE: Gear shift issue
aw...guys, one more thing....anyone knows how can I put my hands on a owner manual?
Old Apr 7, 2006 | 09:56 PM
babyhuey's Avatar
How does the transmission oil look Bear? Below is a drawing of location of check and drain plugs. Just look on the bottom for drain and side of trans closest to radiator for the check and fill plug. If it is gold in color and takes a 23mm wrench to remove it you found them. Oil level should be just to the check plug hole and maybe dribbling out a bit with the plug removed. A good oil change using 2.8qts of a good 75W-90 sythetic might just fix you right up.
Here is link to e-bay for the manual. Free shipping and Buy It Now for only $14.95 can't be beat.
http://cgi.ebay.com/ebaymotors/A-200...QQcmdZViewItem
[IMG]local://upfiles/1377/7B2AACC5ED55446396D95E5B05B4A198.gif[/IMG]
[IMG]local://upfiles/1377/6BA25AE9C16F4DFB94B500F9531D6600.gif[/IMG]
Old Apr 8, 2006 | 09:06 PM
Bear's Avatar
thanks alot man, I didn't check the transmission oil...I will do it soon. I mean I have to change the oil in about 600miles (which I'll do in about 2 weeks),
so it will be the righ moment.
Thanks again
vicky
Oct 12, 2007 06:41 PM
greyhoundbabe1991
Aug 27, 2007 09:12 PM
happytolearn
Jun 29, 2007 11:30 AM
vgmgc
Sep 30, 2006 11:24 PM
Lucky Chic
May 3, 2006 11:00 AM
