Front stabilzer control link
Old Apr 19, 2009 | 10:14 PM
G_D_M's Avatar
Default Front stabilzer control link
Just found a rattling noise everytime I went of bumps and check stabilizer control link , and it;s moving. I thinking of replacing it myself. Does it just consist of removing the 2 nuts to remove it. Is it under any tension from the suspension?Looks easy enough to do . Just don't want any surprises when removing it/.
Old Apr 24, 2009 | 01:55 PM
Estlander's Avatar
Yes, it is very easy to do, and it is not under any tension really. I've opened mine several times. If you take the nut off and the link doesn't detach, you can take another jack and put it under the control arm to support it and jack it up a bit.
Old Apr 26, 2009 | 07:59 PM
copierman's Avatar
easy fix to complete, I've had to CAREFULLY grind nut off. plastic socket on a metal ball joint. I've done the front 5 or 6 times and now the right rear is doing what yours is doing. remember to support stabilizer bar, good luck
jtrumble
Dec 2, 2009 02:49 AM
Prentice
Jul 27, 2008 07:09 PM
sonnystables
Jul 6, 2008 11:17 PM
REDKAISER
Dec 20, 2007 02:52 PM
morris95626
Jun 13, 2006 10:50 PM
