A coolant nightmare in a 93 Protege
Old Nov 29, 2007 | 05:23 PM
wishihadawankle's Avatar
Default A coolant nightmare in a 93 Protege
Just bought a 93 Protege with 150k on it. When i crank up the heat it stays cold and then the moment it starts to get warm, the car begins to overheat. After a little while, the gauge will drop back to normal and then it will run fine. I figured it would be the thermostat so I put in a new one for 6 bucks, but it still does it. What is causing that?
Old Dec 2, 2007 | 11:49 PM
protegedon's Avatar
Default RE: A coolant nightmare in a 93 Protege
Try backflushing the entire cooling system or have a shop do it. Also, don't forget the radiator cap. Also make sure the fan is working and that the AC condensor and radiator fins are not bent of obstructed.
[align=left] [/align]
Old Dec 3, 2007 | 10:09 PM
wsoape281's Avatar
also, you could disconnect the hoses and run a water hose into the bottom hole and turn it on. if anything comes out of the radiatior other than water and coolant, the radiator could be clogged.
Old Dec 8, 2007 | 02:39 PM
tmilburn's Avatar
There is two additional possible issues with the cooling problem. There are two temperature sensors on this vehicle. One is located in the housing of the thermostat and the other is ontop of the radiator. Either one that fails will create the same symptoms.
dcleathem
May 26, 2009 03:27 PM
Tidefan00
Apr 29, 2009 11:03 AM
lakechewbacca
Mar 14, 2009 05:00 PM
mcgiverdave
Jan 28, 2007 03:26 AM
calvin
Oct 4, 2004 10:37 AM
