confused
i have a 2002 protege 5 one night the battery died. I replaced it . and the batt. light came on immediately.
I then replaced the alternater, (all going off local parts houses advice and testing intraments) then the car did the same thing . I took the "old" alternater in for a bench test and it was good. the batteries are dying, loosing power? i have no clue
I would take it someplace that can test the output of the alternator when it is in the car under load. You can use a multimeter to measure the voltage at the battery with the car running. The next thing you will want to do is check the amperage the car is drawing. You'll need to find someone who has an electrical system diagnostic tool. If you can get this done, check the starter to see if it is drawing unnecesary amperage.
