CAN'T SHIFT INTO 2nd, 4th , or Rev
Old Sep 22, 2005 | 05:41 PM
paulie52's Avatar
Default CAN'T SHIFT INTO 2nd, 4th , or Rev
I own a 1994 Protege with 100k. It's been running and shifting fine. All of a sudden, I can't shift into second, fourth, or reverse. First, third, and fifth still work fine. I've never had or seen anything like it. Any advice?
Old Sep 23, 2005 | 12:11 AM
bkey71's Avatar
Default RE: CAN'T SHIFT INTO 2nd, 4th , or Rev
The only thing I can think of is the shifter bushings, as described in another thread right here. Sounds like there might be a lot of slop in the shifter linkage not letting the gears engage.
Old Sep 23, 2005 | 10:27 PM
babyhuey's Avatar
That is a really odd one you have. Can safely say have never run across that before. Could be internal trans in the shift forks but would not expect all three positions to lock out at same time. If you can, I would get up on stands and look closely at the shift rod from where the shifter exits thru the floor up the the transmission and first make sure there is nothing lodged in the way to keep shift rod from moving forward towards transmission. At least a place to start that doesn't involve taking things apart.
One other thought. Does the position of the shifter when in gears that it will go into, feel to be in the same spot as before? ie. when in first gear is the shift **** where it always used to be or has it moved.?
Old Sep 23, 2005 | 10:38 PM
paulie52's Avatar
Thanks for responding. I will get under the car and take a look. The gear positions seem exactly the same as before.
isaac2484
Nov 8, 2019 09:45 AM
stevenhs
Mar 19, 2015 08:08 PM
waynegemma
Mar 23, 2013 09:31 PM
waynegemma
Mar 23, 2013 03:02 PM
BobbyC
Sep 28, 2009 10:33 AM
