Can I assume
Old May 8, 2017 | 05:50 PM
djmarch's Avatar
Default Can I assume
Listened to my daughters 2001 Mazda Protégé as she pulled into the driveway this evening. Sounded like a low bellowing noise as she let off the gas and put in park...Never quite heard a sound like this coming from an engine,,,,So I lifted the hood and the sound was coming from under the valve cover when I revved up the engine by hand while running and then let go...A low bellow sound came as the rpms went back to idle. So I removed the oil cap and gush of air is escaping...Pretty strong. So assuming I have a plugged PCV valve. Does anyone disagree ? Or any other ideas out there on what it could be ?
Thanks in advance
Old May 10, 2017 | 12:13 AM
bob2003's Avatar
PCV valves are dirt cheap, just change it and see if it fixes the problem.
By the way this is one of the quietest forums I have ever been a member of.
People post and no one answers.
Check out my post for an extra vacuum hose, to date 94 for people have looked at it and I have not gotten a single response not even a welcome to the board.....
https://www.mazdaforum.com/forum/maz...does-go-38216/
Cheers to you, I hope you get your PCV problem solved soon.
Check back in and tell us what happens.
jaimie08mazda3
Oct 20, 2007 11:10 PM
