-   Mazda Protege (https://www.mazdaforum.com/forum/mazda-protege-23/)
-   -   A/C question (https://www.mazdaforum.com/forum/mazda-protege-23/c-question-26763/)
tanprotege Jun 1, 2011 02:48 PM
A/C question
Hi guys. I have a '98 Protege LX, 1.5L. The A/C clutch bearing is shot. Is it possible to replace the A/C clutch including the bearing without taking the A/C compressor out of the car? It sits mighty close to the sidewall.
My A/C worked but made a lot of bad bearing noise. I currently use a by-pass belt.
Thanks in advance.:confused:
tanprotege Jun 4, 2011 01:43 PM
This message gets a lot of looks but no answer yet. If you can't answer my question directly I definitely will appreciate if you could tell my how you dealt with replacing the AC clutch bearing, short of installing a new AC compressor.
Thanks!
tanprotege Jun 13, 2011 02:13 PM
Hi guys: Since no one cared to answer I have to answer the question myself: yes, you can. Remove the wheel, remove the under body splash guard and access the compressor from below. There is enough room to work on the compressor clutch assembly.:)
captaintony Jun 17, 2011 01:25 AM
help
I am having the same issue in my 96 protege 1.5L the ac works great except the compressor clutch assembly is going out(grinding noise)... i have done a of research online and cant seem to find the clutch assembly, it seems like i have to buy a new compressor and clutch assembly that sucks!!! 1.5 yrs ago i had all the ac stuff replaced and i want to get out of this fix for cheap any insight would help.
webf2011 Jun 28, 2011 06:20 AM
I didn't face such issues yet. Even am still awaiting for the best solution to this problem, so that in future i can deal them easily.
tanprotege Jun 29, 2011 08:43 AM
I ordered my compressor clutch bearing from "Coldzone777" and I watched YouTube videos on how to replace the clutch bearing. I had no problems getting it done in about 2 hours, and I am a slow poke.
