AC Problem
Old Sep 24, 2013 | 06:24 PM
Rus's Avatar
Rus
Default AC Problem
2001 Mazda Protégé 2.0 LX model.
When I turn on the AC I can hear the compressor working. When the fan speed is 1, 2, or 3 the AC button is green, the compressor is working but no air is coming out of the vent.
When I turn the fan speed **** to 4 the AC button light goes out and I have air flow from the vent. The hose from the compressor is cold to the touch but the air coming out of the vent on 4 is not cold.
Old Sep 24, 2013 | 08:05 PM
tanprotege's Avatar
Does it make a difference which direction you send the air, defrost, body or feet? the dial on the right:
some cars have trouble with the blend door. I don't know if this is the correct year. This is taken from the Autozone repair guides http://www.autozone.com/autozone/rep...96b43f8037cdb3 :
maybe one of the wires is disconnected or damaged.
I hope this takes you in the right direction.
Old Sep 24, 2013 | 09:00 PM
Rus's Avatar
Rus
some cars have trouble with the blend door. I don't know if this is the correct year. This is taken from the Autozone repair guides | Repair Guides | Control Panel | Removal & Installation | AutoZone.com :
Makes no difference.
Old Sep 24, 2013 | 09:32 PM
tanprotege's Avatar
Check if the wires are in the proper places and properly adjusted.
Old Sep 24, 2013 | 11:34 PM
Rus's Avatar
Rus
If you're referring to the temp **** it operates OK. The problem seems to be isolated to the speed control unit.
Old Sep 25, 2013 | 08:32 AM
tanprotege's Avatar
You are not providing details. I can't help.
Old Sep 25, 2013 | 11:32 AM
Rus's Avatar
Rus
I have the temp control **** turned to coldest setting (Knobb of the left). I have the air direction **** turned to upper vent outlet (**** on the right).
When I turn the middle **** (AC on; fan speed) to 1, 2 or 3 setting the AC light shows green, I can sense the compressor is on and the hose is cold but no air flow.
When I turn the same **** to #4 position the AC light turns off and there is air flow but not cold air.
This is my best attempt to explain my problem and I do appreciate your help.
Old Sep 25, 2013 | 04:21 PM
Kevinkpk's Avatar
Do you have any air flow at all in any position through the windshield defrost?
Old Sep 25, 2013 | 04:51 PM
Rus's Avatar
Rus
I have air on all settings including windshield only on speed 4.
Sometimes, on 4, the green light on the ac button turns on and I have cold air. Other times the light does not come on and I don't have cold air.
This applies to speed 4 only.
Still no air from speed 1,2, or 3 in any of the vent settings.
Old Sep 25, 2013 | 05:23 PM
Kevinkpk's Avatar
Don"t know what the fan setting has to do with it, but intermittent a/c on/off I suspect low freon, and the low cutoff switch is controlling the compressor on/off as it should. I'd advise having the freon checked. Is this the original compressor?
