95 protege 1.5L auto Runs then will stall
Old Feb 11, 2008 | 04:26 PM
electrondoc's Avatar
Default 95 protege 1.5L auto Runs then will stall
This will start fine and runs for a while-then when you accelerate acts like its running out of fuel and stall repetedly unless you pump gas fast and hard-it will get into higher RPMs then run until you slow down again but bogs down along the way. When car cools it runs fine again. Have replace air filter, plugs, wires, MAF sensor, ECU and fuel filter. It has been suggested that the fuel pump is the culprit. Is ther a problem using one of these higher output fuel pumps such as the Walbro for this vehicle and do you have any further suggestions-There are no codes stored-Thanks
Old Feb 11, 2008 | 05:57 PM
wsoape281's Avatar
Default RE: 95 protege 1.5L auto Runs then will stall
could be the fuel pump. the only thing that i recommend with those high outputs is that you need to regulate a 255 pump down quite a bit. it isn't bad for the pump, it just sends more fuel back to the tank in the return line.
Old Feb 12, 2008 | 08:40 AM
motorhead5673's Avatar
Got any engine codes??
Is the Intake Air Temp Sensor part of the MAF in 95?
Old Feb 12, 2008 | 06:58 PM
No codes intake air sensor has also been replaced!!
Old Feb 15, 2008 | 06:46 AM
Throttle position sensor?? Seems like you'd get a fault for that though. Anywaythere should be a way to check the voltage with throttle closed and open. I may have a manual at home with this info if you don't have access to it.
Old Feb 22, 2008 | 09:12 AM
no, i dont have that info-if you cansend it that would be great
jenga
Jan 23, 2010 04:48 AM
cicacola
May 4, 2008 08:25 AM
cicacola
Apr 21, 2008 11:27 PM
electrondoc
Mar 11, 2008 08:45 AM
