2000 protege 1.6L po171 issue
Old Jul 7, 2021 | 10:39 AM
Jlogan148's Avatar
Default 2000 protege 1.6L po171 issue
So im driving a 2000 mazda protege since someone hit my old car and a po171 code keeps coming on and off. Ive looked up possible causes but im curious if since its going on and off if that narrows it down or not? Brother said to replace o2 sensor which can be a factor but so can other things; vacuum leaks, maf sensor etc. Any help much appreciated
Old Oct 24, 2023 | 12:08 PM
Blader's Avatar
Hi most likely intake manifold gasket is leaking. I just changed mine out good luck
Old Oct 25, 2023 | 07:36 AM
Celtickid's Avatar
I have one or two theories.
​​​​​​The O2 sensor measures the amount of oxygen in the exhaust gases and helps the engine control module (ECM) adjust the air-fuel mixture. An aging or malfunctioning O2 sensor can certainly cause a P0171 code. Also Vacuum leaks can introduce unmetered air into the engine, leading to a lean condition. Check for any damaged or disconnected vacuum hoses or gaskets.
Jesse Stretch
May 26, 2020 11:01 AM
Karmz
Nov 5, 2017 06:51 PM
loppol51
Aug 10, 2011 03:17 PM
IsaacpBall
Mar 9, 2010 09:15 PM
eajung1
Feb 15, 2007 05:52 PM
