1999 Oil Pressure Sensor replacement
Old May 10, 2011 | 02:23 PM
bbortnick's Avatar
Default 1999 Oil Pressure Sensor replacement
Hi all;
I have a `99 1.6l automatic Protege.
Does anyone have advice about replacing the oil pressure sensor (which I understand is on the back side of the engine?)
Thanks for your help,
Barry
Old May 26, 2011 | 11:45 PM
bbortnick's Avatar
Default two oil pressure sensors
Hi;
I crawled under the car today, and sure enough, there is a sensor above the oil filter on the back side of the engine.
I am wondering if there is a second sensor? The dealer claims there is another one, and the parts diagram for the 99 protege shows a sensor to be located on the front right (driver side) of the top end. However, all I can see there is the electrics for the spark plugs...
Any additional thoughts?
Thanks,
Barry
Old May 29, 2011 | 10:26 PM
Highorder77's Avatar
Barry,
The service manual I have shows one and only one oil pressure switch which is the one you located near the oil filter. Removal and replacement is straightforward. The manual recommends a light coat of silcone sealant on the threads (doesn't specify a particular type, but obviously it needs to be oil resistant). Tightening torque is 9-13 ft-lbs.
BTW - I have a 99 w/ 1.6 also.
Hope this helps...
J
Old May 30, 2011 | 10:53 AM
bbortnick's Avatar
thanks for the info J; much appreciated.
Barry
Old Oct 14, 2011 | 10:03 PM
meGrimlock's Avatar
i am stuck in the dumbest hold up...the wire connector wont come off the switch! i'll pulled and pushed and squeezed and yanked. i'm afraid to do something to that stupid wire. how did you get yours off? thanks
Old Oct 15, 2011 | 10:24 AM
bbortnick's Avatar
Default wire
Hi, I never did replace mine.
However, I did notice the wire terminal was very hard to remove.
I suggest you don't worry, and just cut the wire. Have a new terminal available for the new switch, and crimp it on...
Dave De
Apr 30, 2015 07:59 AM
Tanzanite
Jul 18, 2014 06:24 AM
gilles_o99
Dec 31, 2010 01:25 PM
mayberry56
Jun 17, 2010 06:48 PM
d4tonyd
Feb 2, 2009 08:35 PM
