1998 Mazda Protege LX P1195 Problems
Hello! My Mazda Protege has the P1195 Code. I've had this code for quite a while now. I replaced the boost sensor but I'm still getting that stupid code. If anyone can help me out that would be really great! Thanks!
Read the unofficial user's guide.
There is a vacuum line going down from the sensor and behind the intake manifold. pull that line off and poke in there with a length of wire. I bet that nipple is clogged up.
Poke through!! Use about 3" of wire. I used a bicycle spoke and cut it with diagonal cutters at 45 degrees. That makes a sharp point. I bent the other end to make sort of a handle. A coat hanger should work just fine.
