-   Mazda Protege (https://www.mazdaforum.com/forum/mazda-protege-23/)
-   -   1996 mazda protege cam position sensor (https://www.mazdaforum.com/forum/mazda-protege-23/1996-mazda-protege-cam-position-sensor-33647/)
daquane25 May 11, 2014 02:29 PM
1 Attachment(s)
i'm trying to inspect my camshaft position sensor in my 96 protege. i'm following the instructions listed in the workshop manual on page f2-45. I got to #4 and I need help.. I don't know what an engine signal monitor is. also, you can txt me at (205)764-8454 thanks..
grim_reaper May 14, 2014 05:11 AM
It appears the Cam position sensor is part of the distributor.
daquane25 May 14, 2014 09:54 PM
yes, I was very surprised when I found out. Kind of a bummer considering the fact that it's not serviceable.
tanprotege May 14, 2014 10:09 PM
daquane: sometimes there is an O-ring failing and lets oil into the part that contains the sensor. If that is the case you may clean it up and replace that O-ring.
daquane25 May 19, 2014 05:38 AM
5 Attachment(s)
here are a few pics of what i got
tanprotege May 19, 2014 09:30 AM
Looks rather evil doesn't it.
Take the cap and rotor off. There should be a cover below the rotor. Below that cover sits the cam position sensor. Get some electronics cleaner that will completely evaporate and spray it clean. Put it back together with a new O-ring and cross your fingers.
This diagram is of the wrong year. Non the less it should help you. Instead of a "crank angle sensor" you have a cam position sensor. Also the coil is built into the distributor.
https://www.mazdaforum.com/forum/dat...L+sT/5rSlKD//Z
daquane25 May 19, 2014 05:36 PM
hey i can't get the rotor to come off. is there a specific way i should remove it?
tanprotege May 19, 2014 09:19 PM
It is just pushed on. Be prepared to replace it. You could try tapping it loose with the handle of a screw driver used as a hammer.
How old is that rotor ?
My link to the picture did not work. Hopefully this will:
http://www.google.com/url?sa=i&rct=j...00639044231347
daquane25 May 19, 2014 09:30 PM
That's exactly what I was thinking I had to do. I believe it is the stock rotor from the factory because it is a Mitsubishi part and I also noticed that the crankshaft position sensor was a Mitsubishi part too.
tanprotege May 19, 2014 10:10 PM
There are a lot of Mitsubishi parts throughout the car, mostly sensors and electrical parts. I bet it would be a good thing to replace the cap and rotor anyway. If you agree you can gently chisel the old one off.
